72Duster440
Last winter I swapped out my steering to the 73 and later style centerlink, pitman arm and idler pulley to make clearance for a new oil pan. I didn't notice at the time that I had a clearance issue, but while I was under it last weekend, I noticed the body of the TRE and the zero fitting were rubbing the torsion bars.
Has anyone come across this before? I assume the only fix would be to raise the ride height in the front slightly?
72 Duster, 1.03" torsion bars, 73+ style steering with 72 and down tie rod ends.
