taco502001
- Joined
- Nov 9, 2005
- Messages
- 73
- Reaction score
- 2
Well I have finally done my research and with my cars setup i am looking to install a new converter and 4:10 gears. After talking to scott brown and scott marrison I am looking at a 9.5" 4k stall from ptc and going with richmond 4:10s and rebuilding the rear end. They have both assured me that with what car has should run 11s easily. If you guys have input on other converters and gear setups to go along with car setup let me know
Cars Specs:
71 dodge demon bone stock as far as interior and any weight reduction is concerned
440+6 Block out of 70 challenger
brand new forged rods, crank, and pistons
Supposedly previouse owner had it blueprinted and balanced i am still trying to acquire the paper work.
milodon 7qt deep pan oil pan
906 heads with port work, comp cams double springs, valve locks etc.. valvetrain should be good up to .600 lift
Comp Cam Kit was installed by previous owner supposedly 292/502 cam heres closest one i can find
Big-block B/RB Hydraulic, single-bolt RPM range:3000-6200/Adv. Duration:292 Int. 292 Exh./Duration at .050 244 Int. 244 Exh./Lift .501 Int. .501 Exh./Lobe separation angle: 110.
weiand team g single plane topped off with demon 850 carb
mallory unilite distributor with mopar performance orange box
hooker 2" fenderwell headers
built 727 with manual reverse valve body and shift kit
8 3/4 rear end
Cars Specs:
8 3/4 rear end
