Beams
Good evening,
Working on a 1965 Dart with a 225 from 1974, has an Autolite 2100 on top, with electronic ignition conversion done by previous owner.
I’ve been dealing with some long-standing starting issues that I’ve had with my car generally being: no start and backfiring through carb, or just hard starting. Car usually runs okay once started, but will oftentimes die (seems like vapor lock).
Using a timing light, I adjusted initial timing to about 12 BTDC based on the motor’s behavior (rpms, bogging, etc.). Car is starting well at the moment, sounds pretty good. Drives much better than prior to the adjustment.
THE NEW ISSUE IS: When driving the car around the block, the oil light started flashing when shifting, or when coming off the throttle. Eventually the light came on more consistently, and would stay on, but sometimes flash with the same rhythm as the motor. No real difference in the oil light if at idle, or driving. At one point, the light came on with only the key ignition, not running.
I started by checking oil—let the car sit, oil looked okay. Looking now for my oil pressure switch, and found the switch with no wire attached. I may be young and dumb, but I imagine there’s no Bluetooth option for oil pressure sending unit. Is this correct?
Could not find another sending unit in a different location like the side of the block. Now I’m wondering if there’s a stray wire somewhere in the dash making contact. Maybe it’s hooked up somewhere that I’m not seeing—either way i can’t tell if it’s bad news or bad coincidence.
Sorry for the paragraphs—just want to get as much info out there to start.
Appreciate your time.
