so any year will workYes, 170-198-225 are identical.
Just an FYI. The crank sprocket and the chain is the same as a big block Mopar. Only the cam sprocket is unique to the slant six.Yes, 170-198-225 are identical.
I thought I had heard that. Great, I have a big block crank sprocket that is keyed with various advance/retard slots. Now I just need a /6 cam gear for a roller chain.Just an FYI. The crank sprocket and the chain is the same as a big block Mopar. Only the cam sprocket is unique to the slant six.
Cloyes S-338I thought I had heard that. Great, I have a big block crank sprocket that is keyed with various advance/retard slots. Now I just need a /6 cam gear for a roller chain.
Great, Thanks Charlie.Cloyes S-338
I hope you know that when you use one of the optional crankshaft sprocket advance-retard slots, you must align a different mark (triangle or square, instead of dot) with the matching mark on the camshaft sprocket. That Cloyes S-338 sprocket has just the single dot (for "straight-up" timing). It is really just a tooth number you must get correct on the cam sprocket, but without the mark as a guide, one could make a major mistake (crash valves into pistons). Of course, if smart and you use a timing wheel, you can probably assuredly set valve advance or retard.... I have a big block crank sprocket that is keyed with various advance/retard slots. Now I just need a /6 cam gear for a roller chain.
