Does anyone know where to get replacement parts for timing lights?
I nhave a kal-equip model 4185 dial back timing light and the other night i was trying to help a friend time his small block chevy and he dropped my light on the concrete and it busted the dial knob to ****. I pulled my truck in to check the initial timing with it to see if it was still working and it read 14 degrees at idle wich is what i have always had it set at. I would like to be able to find a replacment dial knob for it, but i have not had much success in finding one.
I started to look at other lights and i can get a brand new actron model cp7529 for 65 bucks and its digital with rpm read out on it, and i'm pretty sure my kal-equip light is made by actron too.
But then i started reading about these digital timing lights not being accurate with cd ignition's. I am running a crane cams hi-6 but my older dial back kal-equip light has been doing just fine reading my timing. I have checked tdc with a piston stop and my kal-equip dial back light has read my timing just fine with the crane box, so i dont see why a newer digital light would have any trouble?
