My experience says different.The mark will be a 90 degrees from the mark you have
My 67 has a 70 up timing cover when I check the timing on the 67 mark it is at what I set.
If I choose the correct cylinder to check on the 70 timing cover it comes out not the same. IIRC seems like it is 5 to 10 deg advanced or retarded don't recall which.
