I've seen timing retard on the old Mopar orange boxes. Was always told that's how they were designed. I've used the chrome box. No retard. I'm not gettin in this fray, just saying what I've tried and seen. I've also heard and read here on this forum that the old Standard LX101 box does not retard timing. I've never verified that myself. I cannot remember......it was either @moper or @oldkimmer who said that about the LX101 I think. Maybe they'll chime in.
Also, I cannot speak about the MSD stuff, as I have never used it. I know people who do and have never once heard them say the box retards at high RPM.
He is. He's posted occassionally on a moparts and RFS.
The way I'm understanding this is if a box, in this case a CD box, simply works from the distributor signal (pulse) there will be noticible timing loss in the higher rpms. (compared to what the distributor is actually doing).If I get a chance Sunday I'm going to call Tuner. I'll ask him again about being able to account for slew rate in electronics. I suppose it's possible.
The last time we talked about it (when I bought my distributor machine) we covered several areas and IIRC one was not being able to electronically cover for slew rate. At least not with common CDI type boxes.
In fact, one of his classic stories is about changing over from points to a CDI box and using 3 different timing lights...and the circus act that followed. Classic Tuner story.
I told him to write a book, but he won't. I told him I'll proof it for free. And buy the first 5 copies.
Now I've been trying to figure out a misfire/stumble that happens above 5800 rpm. I Thought would double check my timing at higher RPMs. I perform a static timing check @ 34degrees ( For you non EFI guys this is like locking out your timing) and it stays pretty steady with minor fluctuations but once I get to 4-4500rpm in drops to 30 degrees. No matter how much I adjust and add to my inductive delay I still get that drop and timing retards. If I add too much inductive delay , the RPM below 4000 it will advance the timing as it should but once it gets above it retards back to 30 and fluctuates.
Copying FB links is PIA. (in other words can't figure out what I did before. )
But one of the videos is in this post - hopefully its visible.
Mopar orange box retards timing?
He's the only guy I'm aware of that has video of it on a machine, but I've seen it live on engine and machine.
I think what @KitCarlson is telling us is that if a box compares two signals, one from the distributor and the other from the coil, then the box can be hard programmed to address the delay.
I don't know if Holley's CDI can do that, but I am puzzled that it seems to be a stepwise drop. At least that is how I understand the original post.
