I thought about changing the water pump but, thought that would require changing the radiator. I had a difficult time finding this one and now believe it is not correct either. Lower hose is on driver side, upper is in the center. May end up changing the water pump and going with an aluminium radiator.
Don't want to leave a bad situation for a future owner...
You may want to consider asking these questions to yourself:
What side does the lower radiator hose need to be on to match the radiator that you plan to run?
Which water pump will have the outlet on that side to match?
Once you figure out which side you need the lower radiator outlet on, then get the proper vintage/year timing chain cover to match the water pump.
If you need to use a cast iron water pump, get a timing cover from a 64-69 273/318/340.
If you need to run the aluminum water pump, then get a timing chain cover from any 70 and later 318/340/360. Mancini Racing also carries repros of the later timing chain cover if needed...
Then once you get the front end of the engine put together, use the proper vibration damper for that engine and crank combination. If the timing marks do not line up, then find true TDC with a piston stop tool and then with the engine at TDC, put a mark on the balancer to match up with the TDC 0° mark on the timing chain cover and now that is accurate for your engine...
Then put the engine to 10° before TDC and then turn the distributor so the rotor is pointing to the #1 spark plug terminal on the distributor cap and then try to fire it up...
If it doesn't start, then try to advance or retard the timing a bump or two until it starts...
Once it's started, get it running around 2000 to 2500 RPM and set the total timing to 34° - 36° advanced and then let it warm up to full temp. After it's at full temp, then start the 45 minute cam break in.
Watch to make sure that your oil pressure is good, then check for leaks from the engine all the way around and underneath. Then make sure that it doesn't overheat by checking the temp gauge every few minutes until you are confident it's warmed up and won't overheat...
Once the cam break in is done, then turn the RPM down and try to set the idle, then tune the carb idle mixture screws with a tune up tach and vacuum gauge.
Then you have completed the first start...
Then comes a quick test drive.... :burnout: :burnout: :burnout:
