olddman
It is me again, and I need someones help with this. Bought new tires for my 1965 Dodge Dart GT, BF Goodrich Radial T/A 205 14R. When I backed out of shop and turned wheels to the right, the left front tire rubbed against the lower corner of the fender. Took measurements and found clearance frome tire to fender on left was 1 1/4 in and on the right it was 2 in. I can put two fingers between the right tire and front lower corner of fender and not able to do same on left side, maybe one and a half fingers. Posted questio on ABodies forum and told it could be bushings. Bushings were bad, so removed and replaced upper and lower bushing, ball joints, and tie rod ends. Measurements are still the same. I have taken measurements of strut rods, K frame to bumper suport mounting bolts, LCR to front of car, and they are all the same. Only difference I can find is in wheel well opening. At the bottom of wheel well opening there is a one (1) inch difference. Right side 31 inches, left side 30 inches. Anyone have answer as to why there is a difference? Thanks
