Tire Clearance
66GTDART
Umatilla, Fl.
Will 215-70x15” tires on 15”x7” rims with 4” back spacing fit the front of a 66 Dart without hitting wheel openings when turning?
I have almost the same setup, 215x65 on a 15x6 rim with 3.75 backspace on the Valiant. It only has a very minor rub at full lock to the right when moving at speed. My suspension is still the original 54 year old stuff, so I suspect when it's rebuilt the rubbing will go away. Your Dart and my Valiant should be the same so I think you will be OK.
Probably going to be too wide for the fronts.
