Tire size
AdamR
Big Member
Bethel, CT
Im currently running 28X10.5-15s on the back of my car but I'm wondering if I should go with a 26" tall tire to pick up a little gear ratio?
030" 340
9.6:1 compression
Magnum heads unported
XE274H 230/236 .513"/.523" with 1.6 rocker 110lsa
650 double pumper
LD340 intake 1" tapered spacer.
1-5/8" headers 3" exhaust
727 10" converter
3.91s suregrip
3300 lbs with driver.
What do you think. I havent had the car to the track yet so I dont know what its going to run.
I haven't had mine to the track yet either, but i'll be running 3.91s with 26" Drag Radials
just in research and after running my 68 mustang with 3.55s and 26" tires, i think i'll go with 3.91 and 26" for the cuda
.............and the mustang will be upgraded to a 3.89 this year
your running a 275-50 right ? Im running a 325-50, was thinking of going with a 295-50
Becuase its cheaper to switch tires then to pull the rear a part and add a new ring and pinion, plus bearings and set-up fees.
Oh so your gonna losse the meats?so when can i expect them at my house for the Zombie :twisted: :thumrigh:
I think im going down to the tire shop to get the best price on the same tires later this week,my girlfriend is getting me some Draglites for my B-day :cheers: ,an the relo kit from mancini should be here on friday neek week :bounce:
AdamR said:
No there not in yet. Its got a 3.23 peg leg in it. :puke:
Oh how cute :tongue: dont worry i was killing chevys with a 7-1/4 an 2.73's an a peg leg,when the relo kit is in an mini tubed the 8 3/4 is goin under :thumleft:
The only thing I was killing with the peg leg was the right side tire.
Peg legs are the best,it was so fun racing an that right tire was smokin the hole time,MMAN GOOD TIMES
