Tire size
AdamR
Big Member
Bethel, CT
Im currently running 28X10.5-15s on the back of my car but I'm wondering if I should go with a 26" tall tire to pick up a little gear ratio?
030" 340
9.6:1 compression
Magnum heads unported
XE274H 230/236 .513"/.523" with 1.6 rocker 110lsa
650 double pumper
LD340 intake 1" tapered spacer.
1-5/8" headers 3" exhaust
727 10" converter
3.91s suregrip
3300 lbs with driver.
What do you think. I havent had the car to the track yet so I dont know what its going to run.
I haven't had mine to the track yet either, but i'll be running 3.91s with 26" Drag Radials
just in research and after running my 68 mustang with 3.55s and 26" tires, i think i'll go with 3.91 and 26" for the cuda
.............and the mustang will be upgraded to a 3.89 this year
your running a 275-50 right ? Im running a 325-50, was thinking of going with a 295-50
Becuase its cheaper to switch tires then to pull the rear a part and add a new ring and pinion, plus bearings and set-up fees.
Oh so your gonna losse the meats?so when can i expect them at my house for the Zombie :twisted: :thumrigh:
I think im going down to the tire shop to get the best price on the same tires later this week,my girlfriend is getting me some Draglites for my B-day :cheers: ,an the relo kit from mancini should be here on friday neek week :bounce:
AdamR said:
No there not in yet. Its got a 3.23 peg leg in it. :puke:
Oh how cute :tongue: dont worry i was killing chevys with a 7-1/4 an 2.73's an a peg leg,when the relo kit is in an mini tubed the 8 3/4 is goin under :thumleft:
Peg legs are the best,it was so fun racing an that right tire was smokin the hole time,MMAN GOOD TIMES
