Terry Dingwell
Looking at replacing the tires on my Demon. Will the stock Rallye wheels accommodate a wider tire on the rear? Currently P245/60R14 on the rear and P235/60R14 up front. Thanks!
I’m new at this game so I appreciate your answer/advice. Thank you.What 14" tire is made that is wider than a 245/60-14? Are you looking at drag tires?
Factory small bolt rallies are 5.5" wide.
Aftermarket has or had small bolt rallies in 6" wide. Some don't fit over the stock Kelsey Hayes 4 piston disc brakes. Not sure if more than one vendor made these.
Thank youStock rallys are not wide enough for what you have so the answer is no.
Thank you for the info. I may have to source out a set of 15” rallyes to make this happen.Terry, to the best of my knowledge there ARE no wider 14"tires than what you have on the back now.
But wider 15" rallye wheels are available, you'd just have to find some.(yes, in 5 on 4 pattern).
