To Loctite or not???
photorep
los angeles
Hi:
Just putting the final parts together on a 74 Scamp front suspension. All new bushings, tie rods, brakes , calipers and rotors. Should I be using loctite on any of these parts??....particularly the strut rod bushings. The manual calls for 45 lbs of torque on the nut and that doesn't seem very tight.
i dont. there are roll pins for the strut rods, and cotter pins for the steering gear and ball joints. i dont use it on the A arms or torsion bar adjusters for alignment purposes
