To switch to big bolt pattern
Flem Stetson
New Member
Chateauguay, Quebec
Rating - 0%
0   0   0
Hi. I have a 69 Dart I'm building, and I would really like to put Keystone Klassics (now made by Cragar) on it. But they're not made with the small bolt pattern. The axles I need for the rear are available, but the front end is a different story. I would like to buy the parts I need from someone (it doesn't have to be disc brakes, although that would be nice) or find out if there's another way. I heard from someone that a machine shop could just make the modifications, has anyone heard of this being done?
Thanks, Ralph
Thanks, Ralph
Ralph
The parts are from the 73-76 A -bodies you need the upper control arm and
everything to the lower control arm.This site will give you the info you need.
http://www.bigblockdart.com/techpages/dbconversion.shtml
This should help
Jeff
All you need are adapters like these..... sold on EBAY. They are CNC billet
aluminum and strong as heck. They come in different thickness.
I suggest 1 inch wide for your application. I had a set on my GMC Sonoma to fit
Corvette rims on the truck. Never had a problem. They bolt right
on using 4 inch pattern studs and produce a 4.5 inch pattern stud
for you to bolt the new rims on. These are the 2.5 inch thick ones
I had on my truck to get the 9.5 inch wide Corvette rims on without a
clearance issue. My truck went from skinny little tires to awesome fat
squatty look.
4 inch to 4.5 inch bolt pattern adapters cost about $70.00
Wilson
Ontario Canada
Thanks, Ralph
A good machine shop can drill your rear axles and drums as well as the front drums. I chose to go aftermarket axles w 2 1/2" brakes rear and a 73 disc set up on my 69 Swinger, but my 68 dart was drilled and I had no problems.
