71Duster
I've fought with the same issues from day one with my 650 speed demon mech secondary carb. Great mid and high rpm throttle respone and power and poor bottom end.
This car most days wont even do a brake stand. The carb has even been tuned on a gas analyzer and otherwise runs great. I am thinking I should go with vacuum secondaries but the engine shop insits the mechanicals are the way to go.
Am I missing somthing obvious here? Below are the car's specs.
Specs: 1971 Plymouth Duster 340
650 Speed Demon mechanical secondaries, on an edelbrock rpm intake
Stock J Heads 2.02 intake 1.60 exhaust and Crane Gold 1.5 ratio rocker arms.
3.55 gears and a 727 with 3000 stall from SMR, stage 2 shift kit from transgo.
It runs a Hughes cam #heh2328al
111deg lobe seperation/installed centerline 108deg
intake lift .506/ exhaust .524
[email protected] Intake223deg/ Exhaust 228deg
Engine is .060 over with Keith Black Hypereutectic pistons on stock rods and a stock forged crank.
Ignition is an FBO box
