had that happen with my chainsaw, it seems that the wife used all my mixed gas and just put in a gallon on gas back into the gas can and what was left in the gbottle pf mixing oil, it started and ran for a bit then slowed down and felt siezed up. I let it cool down and emptied out the gas and put in proper mix and awayyyy we wentMy gas powered blower just stopped while using it. It looked like and felt like it just seazed-up, but it still cranks. I took it apart, my first ever small engine. Can see the piston, everything moves....what happened?ops:
Run a compression check on it .You said it acted like it siezed, and now it turns over.
2 strokes are prone to exactly that.
They sieze up trashing the rings but can still turn over right after.
How does the cyclinder wall look?
Smear marks on the exhaust side?
Craftsman? It just needs flying lessons.
