Top bow interchange?
TAK65
Mijas, Màlaga
Hi all,
just noticed my 1963 Dart's middle top bow is cracked in the middle. Can someone tell which years interchange with '63? Probably 64-66?
Chances are for hardtop/2 door sedans it is 64-66. For 4 door sedans and wagons it would be the same years. Same for ‘verts
The tough part will be fining a vert top assembly being parted out. Couldn't you just have it welded? You would need to remove the tack strip in it but that might let you hide a scab inside the crack.
