MoparAnglia
Hi there, my name is Jamie and I'm from sunny (?!) England. First things first, I'd like to apologise for crashing this party as I'm sure you'll gather from my user name, I don't have an A-body. In my defense, my little sit-up-n-beg is LA-powered! Or rather it was, and will be again.
I'm looking for a little help or guidance on parts selection. My .030 over 318 will be getting a Scat cast 4" crank, Scat i-beams and the Hughes Engines dished slugs (-18cc) which are being balanced this week.
I'm leaning heavily towards the RHS heads from Brian at IMM with a bit more work (basic street/strip porting job) and a light shave for 60cc chambers. Yes, I'd like to run ally heads especially as the weight saving would have more of an impact in a 2400lb car but, well, these are as far as my budget goes...
I already have Comp Magnum (shaft) 1.5 rockers, an RPM intake and a 650DP which I plan to upgrade using a Proform main body.
Cam selection has me stumped though...I had planned on a big hydraulic flat tappet (XE295HL) to use the Mopar lifter advantage but was surprised to see the low power peak it gave on Brian's 410. I'd like to shoot for closer to, or right on 6k peak to suit my gearing and car weight. Ideas?
I'm not against a Hyd roller as the block has not been finished yet but off-the-shelf grinds look quite small in comparison ([email protected]) and give up lift too. Obviously a rocker ratio change would sort the lift but I thought I'd consult the oracles on this one.:mrgreen:
