Torque Converter in a 904
Jim Kueneman
Sonoita, Az
New build with a rebuilt torque converter through a local shop who the guy is a MOPAR guy. He has done the last 4 for me. Been driving the Valiant on local roads for a few miles less than 35MPH. First real drive. Hit 55 and heard this screeching. Pulled over checked fluids, all good. Turned around back home no noise. Went for another ride and pulled over after 3 miles and loud racket like bearing or something. Back home. On the lift sounded like the TC bolts loose hitting the shield. checked everything and nothing loose. It sound like a screaching, grinding sound. It is working and shifting fine. Can a TC make that sort of racket?
Note it make this noise in park and just running now.
Are the bolts loose at the crank to flexplate? Take the cover off and run it and see what it does. Kim
God I hope not! I know I blue locktighted them and tightened the crap out of them. Good idea though.
Something has gotten loose somewhere along the
line. Or Thrust on Crankshaft or bearing has gone South.
Just possibilities. Hard to definitively diagnose from 300
miles North of you.
miles North of you.
Everything is brand new/rebuilt/restored
That sounds like the converter might be stacked against the pump. I can't imagine a professional would do that though
What does this mean? When I installed the TC I had to pull it back out of the transmission a bit to get the flex plates bolts started. It ran for over an hour breaking in the cam and like I said several miles at low speed without a sound.
Generally, converters make a buzzing sound or sometimes grinding. But they mostly produce the buzzing when the transmission is low on fluid.
Since you had to slide it out a bit you should be good. What I'm talking about is when you don't get the converter stabbed far enough into the trans and the converter's input shaft is pressing against the pump inside the trans. My trans guy called it stacking the pump but I don't think that's your problem.
Here's a resource that explains it better than I can:
https://hughesperformance.com/wp-co...orque-converter-installation-instructions.pdf
How far out did you have to slide the converter?
About what they said. Enough that it was was easy to spin the converter to get the right alignment (360) of holes but not that it could pull it out of engagement. Enough to see a gap. 1/8” maybe
Well this sucks. This is a new old stock shield I don’t think it was cracked when I put it on. Oh well time to break out the welder and do a little shaping
