Torque Converter Rubbing
73Swinger18
Camarillo, CA
I just got my 904 Torqeflite back from the shop after a rebuild. I noticed that if I push the converter all the way back into the tranny it rubs very slightly against the pump housing. I'm hoping that this is normal and the converter will pull forward enough when I bolt it up to the engine to clear. Is this the case?
Yes, that's what you'll experience. You will be sliding the converter forward to bolt it to the flex plate when you install, Don't worry, your good.
