Torque converter
stoot
tennessee
Question can i knock off the weights of a 360 converter and use it on a 318 ?
yes...the weights that are on the face on the converter....
Yes its a 727, i was told by a local trans shop that it would have a vibration if i did that. It has a balancing weight on the outside and weights on the face too. I figure the weight on the outside was for the converter and the ones on the face for the engine right ?
be careful "knocking" the weights off of the converter. A buddy of mine tried that and peeled open a hole in the converter, LOL. Grind the weld, and weaken it before "knocking" it off.
ok, those are likely oem welds, on an oem converter. you can probably knock those off, or wiggle them off with a crescent wrench on the weight.
