torque specs for tierod ends and idler arm
74fldart
orlando, florida
could anyone give me the torque specs for the tierod ends , idler arm and pitman arm nuts . this is for a 74 dart , thanks
No, I allways did tight like a mutha F'er or with a air gun, not ratchet.
Tie rod ends 40 ft lbs. Idler arm 65 ft. lbs. Not sure about the pitman arm. Let me check... One source says 100 ft. lbs. on the pitman arm. Maybe someone here can verify that.
