Torque to Yield intake bolts- replace?
dartslantsix
Klamath Falls, OR
I'm fixing my intake on the magnum and I see that they recommend replacing the intake bolts. The Fel-pro bolts are fairly spendy. Can I go with regular bolts or just re-use?
The engineer side of me says I should replace with TTY but I'm wondering what people with experience say.
Thanks.
Hardware store,definitely. I went basic grade 5 on mine, works just fine.
Factory uses 2 1/4" 5/16 NF, with full threads. Its tough to find 2 1/4" so we use 2". Grade 5 is fine. $2.75 at home creepshow. If you get fancy and get stainless or chrome, use anti seize but other than that, its just a bolt.
I looked at the factory manual last night and it does not mention replacing the bolts. Fel-pro is the only place I've seen TTY mentioned. I'll just get the regular bolts. Thanks for the input.
If the bolts are internal to the engine, Ima thinking, new is best.
But if the bolts are external;
I'd have to say if the bolt takes the specified torque, what would be wrong with that. Set a couple up in a vise and see what happens.Use the correct torque spec sheet and for the correct application.Into aluminum is different than into cast-iron.
No vintage Mope I know of ever used those. That's a fairly modern creation.Maybe 20 or 25 years so far?
I have reused TTY bolts on my personal vehicles, using this test, with Zero failures.
I used stainless. The intake bolts take a very low torque value to snug up to spec.
I dont think they snap due to too much torque, more because they are always corroded and are not a shouldered bolt, threads on entire length, which pass through aluminum manifold into iron .Electrolysis eats them quickly. I would say that on an average, half of the magnums we get in have one bolt with head broken off.
