SRT_DSTRHOLC
"There is never enough horsepower...."
I tried to raise my torsion bar on the drivers side, but it lowered back down. Is there anyhting that would casue it to back out? It still has the clip at the back of it and the nut turns also
huh?at the rear is a clip isnt there?
The front nut that you turn is what i use to tighten it, and to tighten it I would pull the wrench towards me if im on the drivers side, to raise the drivers side right?
By "nut", do you mean the one on the end of the pivot shaft which pokes through the K-frame? If so, that's not how you tighten the torsion bars. They are tightened from underneath by turning the adjusting bolt like you see in the above photo.The front nut that you turn is what i use to tighten it...
ya i fixed it =( I was turning the wrong darn bolt, but thanks guys everythings is all fixed now
