As far as I can tell, all the factory bars are clocked the same. My 1.03 bars were different and need very little preload to set the low ride-height.They slide right in/out with no loosening of any components. Sometimes the epoxy paint on the hexes is lumpy and needs to be removed some;just the lumps.
Take one bar and lay it on a flat surface. If the hex flats on both ends lay flat to the surface, then there is no clocking.By itself, this means nothing.The clocking is there, to provide enough windup on softer bars. A bigger bar doesn't necessarily need it.You simply have to unbolt stuff until it slips in.
However, with a big fat bar, the clocking can be shallow, cuz the wind-up is not needed. Perhaps you are trying to force the arm too far down.Since the bar will start in the back hole before the front, it is just a matter of eyeballing the front socket, to see which way to go.If the LCA pivot pin is not centered in the bushing (making it junk), the bar will not want to enter the socket, cuz the sockets are then not on the same imaginary line.The same thing can happen if the front frame rails have gone soft, carrying the K into a different plane.Those two sockets have to be on the same imaginary line.
Sometimes if the LCA bushing is bad, one has to loosen the pin in the K to bump the socket back into alignment. But if the pin is not centered, it is best to replace the bushing, to restore the imaginary line. To assemble it otherwise is to put a little bend into the T-bar,which they don't like.
Grease those sockets up while you are in there. I use "waterproof" wheel bearing grease from a marine supplier.
