total dash harness replacement for 71 dart
mikes cakes
New Member
Buxton ,Maine
I'm looking to replace my wiring harness in my dash for my 71 dart.
Is there an easy way to do it? Can the dashboard be removed to acsess
The harness?
Thanks,M:newb:ike
Sure dash can be removed. You have to pull your windshield out also. Easy job once the dash has been removed.Good luck and welcome to FABO.
Coincidence, we are replacing the harness in a 71 Valiant. We bought a Year One harness, but beware it does not come with the heater wires. We should be working on ours in the next month. I'll let you know if we get any "snags". We already have the windshield and dash pulled.
It can be done without removing the dash. Lower the steering column and remove the instrument panel.
