TQ gasket advice
dancinwulf
Ketchum Idaho
I have seen where some people run two gaskets under a TQ to reduce the heat
transfer from the manifold. I was planning on running a 1/4 to 5/16 gasket on
mine but was wondering if there is any advantage to running with two thinner
gaskets rather than one thicker or is that just personal preference? I also see
that there or open gaskets and ones with 4 holes is there an advantage to either
type. I believe the original ones were open throat as apposed to the ones that have
two large and two small holes.?
What intake?
I know the OE intake was very sensitive to the gasket used. I used to know the FelPro number off the top of my head because I fixed many of them.
Just saw the other thread and Marco gave you the correct part number. That's what you want.
You'd think I could remember 60273.
Sucks getting old.
