TQ home-brewed choke setups
Captainkirk
Old School Mopar Warrior
Northern IL
Was looking at my TQ today and trying to figure a way to work up a manual pull-choke setup in case I decide to use a non-EGR manifold like an Air Gap.
If you have a successful version of this, how about posting some photos of what you did and how it works for you.
Why not just find a TQ electric choke setup?
I don't know how THIS reincarnation of my 340 will run, but last time around with the Holley on the Torker, I needed choke to START the motor....then once running, it ran like **** (read; ultra-rich) until I opened it full. Even when cold.
If it does the same this time around, I don't wanna wait for a coil to open up.
Of course, it might not, as this is a completely different build. But I would like to have that info available if I need it.
Besides...I haven't seen any TQ choke coils around for some time, even on ebay.
Remember when we messaged about TQs? I told you I had some. I thought you were interested but I never heard back. They DO use a choke pull off. You are aware of that, right?
Do they fit a 6138S? I don't see any provisions for choke housing screws.
I guess I will try to find a photo of one.
I put a $7 Lowes lawn tractor manual throttle/choke cable on mine.
One clamp to hold the sheath and it had to come up from behind the carb.
Not too difficult.
Ugh. Nevermind.
C'mon, Rusty..spit it out. I'm not a mind reader!
I guess you were referring to the whole carb, not just the e-coil?
If so, we can talk...but I'm still quite a way from needing a carb. Gotta win the bottom end war first.
Now it looks like I'm buying new pistons. sigh.
Not too difficult.
I can picture it in my mind. Pretty much a straight shot, angled up under the choke pull-off. Where did you anchor the clamp?
Might have been the other side top body screw.
I have a 750 AFB on it now.
...also may have been on the cowl...hmm...
I ran a chokeless 850cfm TQ with a Performer RPM manifold & adaptor on my 73 Duster340-4spd combo without much issue. On cold weather starts I just pumped the hell out of it or poured alittle gas down the carb prior to starting. With a 4spd you can feather it till it wants to idle good. Warm starts were never an issue.
