Trailbeast HEI System-Looking for one....
318MoparGuy
MoparHokie
Waynesville,NC
I recently chatted with Greg (Trailbeast) and found out that he doesn’t build his HEI systems’ anymore. He said the 4secondsflat system is good, but I don’t need a system like that. I have a stock 73 Swinger and just wanted to upgrade the ignition a bit. I was wondering if someone bought one of his systems and now can’t use it because their build took another direction and they now need a more performance oriented system. Any help would be appreciated.
Thanks,
318MG
I used this setup with a 98 Silverado. I ordered one that had the module and coil together on one bracket, but the module was the 8 pin design so I swapped it out for a 4 pin
There's nothing wrong with what you have. Buy the 4 seconds flat limiting plate, put a good curve in the distributor and go.
The smaller HEI like ignition that you can buy for LA's on Ebay is just a Bosch 4 wire module in a can on the side of a LA distributor. Hundreds of models run this simple ignition module. Bosch ADY17 or BIM024
Oops, meant to ask: can I remove the points and reluctor in my existing 1968 distributor and install the 1973 electronic pickup and reluctor in the same 1968 distributor?
