TrailBeast
AKA Mopars4us on Youtube
A good amount of ideas here, but if I was on a budget (what am I talking about, I am)
I would use a left over AC condenser for my cooler, since they already have the barbed ends on them from the crimped hose fittings.
A trans tech would tell you that changing the fluid temp will change how the fluid flows and therefor WILL change how a stall modified converter will work.
Hotter fluid will make the converter hook up later in RPM's, and cooler fluid will make it hook up sooner.
A converter is just one fan driven by the engine blowing fluid at another fan making it turn and drive the trans via the input shaft of the trans.
However, one can adjust the trans temp by simply covering part of the cooler so it cant get air to the entire surface, but a trans temp guage would be mandatory to be able to adjust that temp as you wanted to.
Now, if you have a stock converter and you run the trans cooler and the trans gets cooled more than it used to you will have later and more firm shift due to the thicker fluid, but also the added benifit of better lubrication due to the thicker fluid.
Make sence?
Make sence?
