daredevil
Looking for clean line install ideas for a trans cOoler. Currently lines are connected to the radiator but I want to use a stand alone cooler that has hose barb connections. Pics are welcome.
I would agree, but when you're poor and in need, welllll you know.
This is the one I installed on my car. Has everything you need.
My understanding is the transmission oil should stay in the 160-200 degree range. If you install a stand alone cooler and bypass the one in the radiator, it may run too cool.I have seen these transmission coolers put between the bed and a cab of a truck with no fan at all and did fine working in the hot fields in Florida at low speeds and run all day, and drive 40 miles to plant City Florida loaded down with about 200 flats of strawberries and did it well over 5 years with out anyproblem, there must be some cool air there or something Pete.
How cool do we need to keep our transmission fluid ?? :scratch:Makes me wonder :-k, we know it hits 180 degree or higher radiator to get cooled, does any tech have info on this ?
oil running too cool will kill stall in the converter.
If you have a converter that runs the way you want it at 190* and run 120* fluid through it, it will not stall or react the same.
