CIC
need help with trans numbers 3425020 j2801543 if can help thanks
The 2801543 is a from a 68 383 although it may have been available in late 67.need help with trans numbers 3425020 j2801543 if can help thanks
Take a look at the top of the bellhousing and see if there are any numbers stamped there.trans is in 69 big block build date 7 14 69 no numbers on pass side
