gold75duster
Member
- Joined
- Mar 28, 2010
- Messages
- 11
- Reaction score
- 0
Hi Everybody,
I have a 75 Duster with a stock 318 and automatic tranny.
I recently discovered that the 318 has compression in all of 5 cylinders and could realy use a rebuild.
I am in the process of pricing out having a modified 360 built for it but am concerned with the rest of the drive train. Engine will have a moderate cam, edelbrock heads, edelbrock intake and carb.
I have the broadcast sheet and it lists the transmisison code as D34 in line 2 (automatic) and 423 in line 4. I have looked on line an can't determine what transmisison it is but it looks like 75's came with the 904?
Will a stock 35 year old transmission expolde if I put the power of a 360 though it (assuming it produces approx 350 HP)? Any ideas on what sort of power these transmissions can take would be helpful.
Should I be looking at having a sturdier transmission installed or rebuilding the existing one? Any idea on ball park figures for a reman tranny would be appreciated.
Also, will a 8.25" rear end be sufficient? I am planning on having the rear end done as it is making noise and want to put some shorter gears in it.
Any advice . thought would be greatly appreciated.
Thanks
Thanks
