Transmission Leak
LPena25
Member
central texas
Hi all I have a 1970 Dodge Dart that I’m restoring. Noticed potentially two leaks from the transmission. One being from the NSS/PSS and another just above that where some linkage goes into the transmission. Just wondering what to do for the linkage leak and which nss did yall buy
There's like 5 different Neutral safety switches, you'll have to pull yours and measure it with a caliper to make sure you get the right one. Mine was leaking through the switch itself (not the threads). There's a thread somewhere with a comparison of the different options.
For the linkage above in your photo, I think that's the kickdown linkage. Unfortinately you'll have to drop the pan to replace that seal.
