Transmission won't find park
wazoo64
York, South Carolina
Just put the engine in with new stall and new tranny pan. For somereason it won't go into park. All other gears work fine. Anyone have instructions or advice on how to fix/troubleshoot?
new converter and pan....do anything else to trans?
remove shifter linkage from transmission...and move trans arm to see if park will engage...
Bump
Any suggestions on this problem or how to fix it? I need details if possble. I dont know much about working on trannys.
..........Its possible its the linkage, was this set up already in the car,up and running/driving ,was it a 6 cyl, consol or column shift,aftermarket shifter........kim.....
