Trick flow 240s on milder builds versus Edelbrock RPMs
The FE ford cylinder head findings will be interesting. For those who have never removed and installed FE cast iron intakes its a real treat. NOT
If I remember correctly. The head make up part of the intake or something like that. Ie. valve cover cover some intake and some head.
A friend has a 427 side oiler in a 49' Ford Anglia. Fastest car I've ever been in.
Sage advice. If you already have the RPM heads......use them.
Simply for reference, on my bench with the only OOTB 240 heads I have tested, here are the airflow differences vs OOTB RPM.
Lift............240 additional cfm
.100..........+0
.200..........+0
.300..........+11
.400..........+37
.500..........+58
.600..........+65
.700..........+53
I do like the additional 240 airflow.
I totally would go with TFS 240 I tried both the Eddy's and TFS and really there is a day/night difference between them. On my 451 with a Perf rpm intake it made 612 hp and 625tq all while getting 12" vaccum. The best I managed with the Eddy was 550hp 575tq. Spend the extra few $$ and get the TFS
What was done to the Edelbrock heads?
As lite as those were , any thing would be fast in it ! All the crazy ford motors I remember , all got beat by hemi`s !
I just cleaned up the flashing and took them apart to check everything. The TFS heads I removed the Ribs from the CNC to eliminate the turbulance and It worked .
I doubt that, but more importantly let's not forget the Ford hemi that made 616hp on a single 4bbl and 657 on dual quads. :poke:
