Trick Flow Track Heat
Big Block A body Tech
  1. Rmoore
    Rmoore Well-Known Member
    243
    114
    Nov 14, 2018
    Gun Barrel City, Texas
    Local Time:
    10:14 PM
    Anyone running this manifold on 493 cubic inch and up b/rb engine that could give me any information on the street/ strip functionality of this intake. Down here in Texas I've never seen anyone run one on a mopar. Much less a low deck 512 that I'm building for my Dart.
  2. Bigdummy
    Bigdummy Not a Nova FABO Gold Member
    8,087
    2205
    Dec 26, 2006
    Cleburne,Tx
    Local Time:
    10:14 PM
    Far as I know trick flow just offers a low deck and a tall deck single plane intake.It depends on the rpm of your engine weather you need one or can get buy with a performer RPM.
  3. AndyF
    AndyF Well-Known Member
    1,315
    1013
    Feb 23, 2009
    Oregon
    Local Time:
    8:14 PM
    I have one on my low deck 512.
    • Like Like x 3
    • Rmoore
      243
      114
      Nov 14, 2018
      Local Time:
      10:14 PM
      Pictures of the trick flow almost identical to the victor. Was wondering if it flowed as well as the victor. But you're even better because you have one 512 what kind of horsepower numbers you make with your 512 with the Trick Flow Intake
    • dukeboy_318
      dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
      32,864
      11383
      Jan 19, 2007
      la la land
      Local Time:
      11:14 PM
      wow! I like that coil pack setup, where'd you get that?
    • famous bob
      famous bob mopar misfit FABO Gold Member
      13,161
      3824
      Aug 14, 2011
      okla
      Local Time:
      10:14 PM
      I stated this in another post, but the track heat intake (up closer inspection) , looks like a cleaned up/smoother victor, to me .
      I think it would be great on a bigger engine ,--------- "just me!
      Andy can let us know how they perform on the street , most likely ---
      • Thanks! Thanks! x 1
      • famous bob
        13,161
        3824
        Aug 14, 2011
        okla
        Local Time:
        10:14 PM
        I would like to see a performance test of a regular coil deal versus the coil set up like he has / its pretty kick a$$ .
        • Like Like x 1
        • dukeboy_318
          32,864
          11383
          Jan 19, 2007
          la la land
          Local Time:
          11:14 PM
          same!
        • Bigdummy
          8,087
          2205
          Dec 26, 2006
          Cleburne,Tx
          Local Time:
          10:14 PM
          Andy did a dyno test on that engine with intakes.Its on the trickflow post in the Big block section
          • AndyF
            1,315
            1013
            Feb 23, 2009
            Oregon
            Local Time:
            8:14 PM
            The Trick Flow intake is better than the Victor intake by a small amount. The best intake I've used on a big inch low deck engine is a ported M1 4500. That intake was good for 750+ hp.
            • Like Like x 1
