Trouble with console shifter linkage
Dkruse
Mira loma california
Adjust shifter linkage and loose park or first gear . Help
[/URL][/IMG]
[/URL][/IMG]
Sounds like the lever on the trans is the wrong one. Those are of different lengths.
Are all the bushings intact and tight? If they're sloppy, you'll have that problem.
I had similar issue putting floor console in column car.
I found the linkage bar on the shifter itself in the car was a little bent and needed some tweaking by trial by error. Got it to work normally afterall.
Good Luck
