[WANTED] Truck Dash Gauge Housing
jonn6464
1970 Duster
Weatherford, TX
Hey FABO!
I know there are some truck guys on this site, so I thought I would take a shot here.
I'm looking for the piece pictured below. It houses the gauges and the circuit board, and continues over to house the radio. I just need the housing, not the gauges.
Mine is a 75 Trailduster, but I'm sure other years will work too. Let me know what you have.
Thanks for any replies.
I think that's the year they converted over from metal to plastic on the housings. I converted my '78 to the early metal housing. The plastic housings had a bad habit of melting around the ammeter posts. Once they melted a bit, the wire connections got looser, connections arced even more, and everything melted more until you had a real problem. I also soldered the ammeter posts to the straps they pass through, and double nutted the wire connections. No way it's coming loose now!:thumbsup:
Hey FABO!
Just out of curiosity what's wrong with the one you have?..
I might have one as well...
I am making a custom dash panel and redoing the gauge cluster. Everything was rolling along nicely and then I remembered that I went with a mechanical speedo. So the threaded connection on the speedo cable is too big to pass through the original speedo hole. I want to keep my original cluster intact so I'm looking for another that I can modify.
If you have one that would be great. Even if it's plastic, as long as the dims are the same I guess.
