Truck P/S Pump in Duster?
Josecuda
Panama Republic
Hi there,
I got a complete 318 from a 1989 B250 to swap in my 72 Duster. I was wondering I could use the same p/s pump and brackets that came out of the truck with no issues. Anyone has done a similar P/S swap in the past?
I say go for it. But please, take it back off and paint it:cheers:
C
The only area that might be a problem will the the pressure hose. You might have to make a custom one depending on which control valve you're using and if anything is mixed between metric and SAE.
