truck trans
ibleedmoparts
Milton, Fl
will a 74' truck trans fit in my duster? Its a 727 i will be putting behind a 360. Just looking for the differences if any
The tailshaft may be a little longer than the car version but you can make that up in driveshaft length. The mount bosses and the bellhousing pattern is the same as a car tranny as well as the shift shaft and kickdown shaft. Should work as long as the truck was a small block and was a 2WD.
