Trunion drive shaft angles?
Babyblue66
Cool dude
In an apartment, MN
My 65 Barracuda has the trunion style u-joint in the front and a standard u-joint in the rear. I Have a slight vibration under acceleration. I am curious about what the joint angles should be, if they should be set up the same as a drive shaft with 2 standard u-joints, or like a shaft with a cv and a u-joint. I noticed it got better when I installed an extra leaf in the rear springs to raise the car a little, but it is still not just right.
It is annoying and I want to get the correct geometry. Thanks.
