trunk battery wiring help
340kid
Can someone please look over the wiring diagram attached and let me know if i have this wired correctly, battery in trunk, solenoid & disconnect switch, also elkectic fuel pump, i want the pump to shut off with the switch, i think i'm ok but looking for advice,
should i use any fusible links anywhere ?
How are you switching the pump on and off?
If you don't mind the alt line being hot all the time, it will pass tech.
fuel pump will have separate switch mounted on dash, the fuel pump will also have circuit breaker and relay before the pump
