I want to relocate the battery to the trunk. Is there a kit that comes highly recommended?
I have always wondered what good it will do a track safety guy to come up and shut off a battery if the alternator output terminal is used to power the B+ side of the car (lights, fuel pump, ignition, etc). Once the engine is running shutting off the battery won't help in that case. I have seen a guy hit the wall with a stuck throttle and just sit there doing a burnout while the driver is knocked out from the wall hit.
I had a car almost burn to the ground by not having a disconnect wired up. If something happens it takes alot of time to get out of the car, grab the trunk key,open the trunk, find a wrench and unhook the battery all the while your electrical system is burning up.
