Trunk, Floor paint question
mikess68
Portland, TN
what color is the drain plugs in the floor of the trunk. they black or body color. ? what about the bolts to the shocks. while your mind is in the trunk, are the inside of the quarters a textured or smooth paint. tks
All the paint on the inside of the trunk is the exact same paint as the outside if the car.
Trunks were painted very quick so the paint is thin and areas that are not easily seen will have little more that primer with whatever over-spray made it there.
Plugs would be black. Inside of the 1/4s have painted undercoating... This undercoating does not cover the entire insides of the 1/4s.
alll right. that what i needed. what kind of undercoating dries hard and paintable? the "rubberized and paintable" lets the black bleed through. thought about spraying /misting it with laq thinner to make it dry out more??
Hmm, when did it change? My 70 Duster trunk was interior color(I bought it new, so no repainting involved)
