watching
Correct on both counts. Having said that, I had a .060 over Chevy 350 about 85 or so. Had the old 12.5 TRW forged domed pistons in it. I had the block first and it was already .060. I knew the forged pistons would be good in it without boring anymore. So I got them NEW from Summit on sale for 99 bucks. It sounded like a diesel until it got warm. But that was one runnin small block. lol It was loose and it would fling like hooker on payday. I had it in a 75 Chevy Monza we put a 12 bolt under.With any of the old TRW forged pistons I can tell you two things I know about them.
1. They are really heavy
2. They require about .008" piston to cylinder wall clearance because they grow a lot when they heat up.
This causes them to make noise with rocking until they heat up, and they consume more oil than a newer pistons of better material that require less clearance.
However, this was all we had back in the day and they worked fine, so they will still work fine. You just need to make sure they get clearanced correctly and make sure the
engine oil and water temperatures are up before you start hammering on it.
Tom
Forged aluminum flat top with valve reliefs, 1.759 nominal compression distance, weight 592 + or - 10 grams, 1.5 cc total valve reliefs and chamfer, pin weight 154 grams, pressed or floating. Compression depends on deck clearance. Anywhere from 9.9 to 7.7 depending on head cc and deck clearance using a .039 thick head gasket. Not sure on clearance, I doubt recommended clearance is .008.What do you guys know about them? yeah they're old. Supposed to be 30-over 318.
Deck height? Compression with running the mill stock heads? Other thoughts?
