Inertia
If it's not popping back anymore, look down the carb when its running, and you'll notice that drip, and the resulting loss of rpm for a few moments after..
Yes like dodge freak said,compression test is in order.Compression test is a good idea too. I looked at the rockers today and the only concern I had was #1 exhaust seemed too loose. I figured it may be a compressed lifter that will fill when the engine runs.
My second concern: the elec choke slowly opens the main carb intake flap fully after a few minutes running. This may sound like a dumb question, but could that be causing a too lean condition, if its fully open?
Today when I started it up it ran fairly smooth at first, and I was feelin pretty good, then got steadily worse when it heated up. I shut it off after 10 minutes because it was missing and coughing too often.
I am concerned about number exhaust being loose and once again I agree with dodge freak on seeing if the rockers are moving the same distance down opening.
On the choke opening the flap after a few minutes that is normal and would not be giving you a lean problem.
Is that when your problem begins?
TXDart
Or he could adjust the choke to stay almost shut all the time until he got that cam broke in.If that is his problem,who knows but I hope he figures it out.But what if there was dirt in the jet or passages, as the choke opens the carb then does get leaner. Simple thing is just push the choke flap down a ways if it moves easy, if not use your hand. That be quicker than a compression test. I'm thinking it was just a lifter bleeding down why the one valve seem loose.
