gregpurcell
Greg Purcell
It's a six cyl factory ac setup. It did not work when I got the car. It was not open however. It was an original r 12 system never upgraded. It was almost (but not completely) empty. I used the Duracool because it mixes with anything. With the compressor on and running (it IS turning) and the gauges attached I get about 70 psi on the low side (if I'm reading it correctly) and zero on the high side. I put a vicegrip on the heater hose to keep the heat out in case the heater control is not working. Obviously it's blowing hot air.
What do I need to change?
Thanks in advance!
Thanks in advance!
