Tuff Wheel adapter question?
GStewart
Hewitt NJ
Purchased an original tuff wheel adapter for my 71 Demon from e-bay, listed as fitting A or B body, went to put it on today and appears the splines are different. The adapter splines appear smaller/finer and do not have the master spline. Is there a difference between the 69 and earlier steering shaft as opposed to the 70 and later? Did a little research and all I came up with is some conflicting information on Little Red/Warlock/Cbody adapters. Would like to positivly identify the one I have so I can resell. Thanks.
If it don't have a major keyway it's for the trucks cars have a major key way and all cars b.c.a.f body's all work
Cant say I have ever seen a different spline. Could it possibly be for a tilt column? Tilts are a whole different animal compared to the standard columns.
No key way is truck as mentioned above.
The splines themselves are also different, so they do not interchange.
I tried a truck one on a car shaft last night before I posted above, no go.
interesting , that I yanked one off a 77 ramcharger steering column and it is now on my dodge charger column , the only adapter I have had in years.
Would any one have the instructions for swapping out the original to a Tuff wheel? I have a 71 Duster auto.
Thanks
